Community Member
Security error
Befor applying license i am able to synchronize to the instances,once i uploaded license file to ELM i am facing the security error?
Purple
Security error
Hi Siva,
can u share the error snapshot ?
regds,
aman
Community Member
Security error
Look out this erro,mean while my ntp is not getting acurate time may be do this?
Purple
Security error
Hi Siva,
Is this fresh installation since Synchronisation Status says "Never" ?
Is ELM installed on a separate server , just to check reachability between CUCM and ELM?
regds,
aman
Community Member
Security error
Hi Aman,
Yes its fresh installation,already done with,initaly status was sucess after inserting license file it shows security error
ELM is not installed in seperate server currently using version 9.1
Purple
Security error
Hi Siva,
I did not understand why u mentioned about NTP ?
In ELM, under Administration---Diagnostic Logs , can u generate the log and share,if something could be found.
also, can u check in CUCM serviceability --->tools---> Control Center--Network Services ->-Platform services ----cisco ELM client service is running or not....
regds,
aman
Community Member
Security error
Hi Aman,
The service are running ,
i have tried this command too admin:license client reset registration
Delete and re−add the instances but still sunchronization fails l?
Purple
Security error
Hi siva,
can u share the Diagnostic logs?
regds,
aman
Purple
Security error
Hi Siva,
can u try deleting the product instance and re-add it ?
regds,
aman
Community Member
Security error
The last synchronization attempt on 2014-Feb-19 06:01:14 failed due to a  certificate error. The last successful synchronization with this instance was  Never
Community Member
Security error
Hi Aman,
I deleted the product instance & readded,
While i am verifying getting error
Purple
Security error
Hi Siva,
Any detailed message you get in Diagnostic Logs related to certificate.
regds,
aman
Community Member
Security error
Hi Aman,
I am unable to take download diagnostic log,its not opening
Community Member
Security error
Finally i resolved this issue,my CUCM& UC are synchronized to ELM
Purple
Security error
Hi Siva,
thanks for update.
What was the root cause ?Can u please share.
regds,
aman
2053
