security on a remote site
We need to extend our internal voice network to be able to access by the staff in a remote location that we dont have any administration.Just wondering if any of you guys have any experience locking down the network just only for voice no data at all
remote site will be using
CISCO 3750 connected via Microwave please refer to the toplogy
Please let me know your ideas,any security implementation on that is appreciated
Thanks in advance
1 ACCEPTED SOLUTION
Re: security on a remote site
Hi there,
Depending on the amount of phones and the amount of switchports, I'd just go for a tight port security setup.
Then only put the voice-vlan ID as both access as voice vlan. (Or you could go and use 802.1x)
You could even further lock it by only opening specific network ports between phones and CUCM by using ACL's on the switch.
Please refer to the following document:
Cisco Unified Communications Manager 7.0 TCP and UDP Port Usage
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/7_0/CCM_7.0PortList.pdf
There's such a document for all major versions of CUCM.
Furthermore, you should lock your switches from physical access if possible. Or at least put some sort of authentication on the local console (sometimes forgotten while only remote access is enabled)
Hope this helps you further.
Cedric
Hi there,
Cedric
If the IP PBX is centrally located maybe the Cisco ASA Phone Proxy is the solution
  1. a Cisco IP Phone
  2. an ASA VPN box
  3. an ASA TLS Proxy license (phone proxy comes with 25 licenses to start then you can buy additional licenses.)
http://www.networkworld.com/community/node/42488
Cisco ASA Phone Proxy Configuration
http://angryciscoguy.com/jello/?p=100
414
