Security token
Hi, we are trying to run encryption between phones and during instalation of CTL client we were asked for security token. We dont have it and we arent sure if we are supposed to have it. Is USB security token in standard package of CCM server and software? Thanks a lot.
Re: Security token
yes, you're supposed to have it
no, it's a separate item which needs to be purchased.
you need 2 of them to enable security
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Security token
I have 2 of them...where can i find a good procedure on how to install/implement security on the phones?
If i can show it to the customer,we are talking about a deal of 15000 phones here...
So any feedback would be greatly appreciated.
Kurt
Super Bronze
Re: Security token
Hi All
A few comments; I've recently deployed this for one of my customers and found a few things:
1) You need at least two security tokens from Cisco (not sure if other ones will work or not, I've not tried).
2) Most phones support SRTP, with some exceptions. Check the data sheets for whatever models you use... once the cluster is in mixed security mode, it's largely just a matter of creating phone security profiles, ensuring phones have valid certificates (which can be done via BAT) and assigning the security profiles.
Detail of this stuff is in the Security Administration Guide for your version e.g:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/5_1_3/sec513.html
3) If you want to run SRTP to a gateway, that gateway will require Advanced IP Services, or Advanced Enterprise services. This IOS is also required for secure SRST, secure conference, secure transcoding etc.
4) Confernecing, MTP based in software on callmanager do NOT support SRTP. You need hardware conference or transcoder resources for this.
Some docs:
Conferencing & XCODEing SRTP
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/itsdsp.html
Gateways and SRTP
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t11/feature/guide/gtsecure.html
Secure SRST (the most tricky)
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/sr_scur1.html
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_example09186a0080509462.shtml
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_guide_chapter09186a00806674c7.html
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
648
