08-14-2012 08:49 PM - edited 03-16-2019 12:43 PM
Hi all,
I am experimenting in our lab with using ENUM lookup and a CUBE (3845 with IOS 15.1(3)T3).
I have followed the document posted on the Cisco example configuration website: http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080ad7b94.shtml
Everything works as per the document. That is, when I run the test enum command, the result is as illustrated in the doc.
However, the call is NOT actually extended using the replacement URI. That is the call is never placed to the destination that corresponds to the resulting ENUM query. Instead we simply respond with a 404 Not Found SIP message.
I have a feeling I am missing something but which I can't seem to identify.
I have never had this working.
The ENUM server is running on a Ubuntu linux server using bind9.
Relevant IOS config is as follows;
ip domain name <our domain>
ip name-server 202.158.213.195
voice call send-alert
voice call disc-pi-off
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 182.255.112.18 255.255.255.255
<and various other trusted addresses here>
no ip address trusted authenticate
address-hiding
allow-connections sip to sip
signaling forward unconditional
sip
session transport tcp
header-passing
error-passthru
early-offer forced
no call service stop
voice translation-rule 1
rule 1 /^02\(.*\)/ /612\1/
voice translation-profile Calls_via_APAN
translate called 1
voice enum-match-table 1
rule 1 1 /^61\(.*\)/ /+61\1/ e164.test
rule 2 1 /^02\(.*\)/ /+612\1/ e164.test
voice enum-match-table 2
rule 1 1 /(.*)/ /\1/ e164.test
interface <snip>
description LAB LAN
ip address 202.158.213.203 <snip>
dial-peer voice 1 voip
description incoming dial-peer matching
session protocol sipv2
incoming called-number .
voice-class sip early-offer forced
dtmf-relay rtp-nte
codec transparent
dial-peer voice 10000 voip
destination-pattern 0297796908
session target enum:1
dtmf-relay rtp-nte
codec transparent
dial-peer voice 10001 voip
destination-pattern 61297796908
session target enum:2
dtmf-relay rtp-nte
codec transparent
dial-peer voice 10002 voip
destination-pattern 33333
session target ipv4:182.255.112.16
incoming called-number 0297796908
dtmf-relay rtp-nte
codec transparent
IOSGK_lab#term mon
IOSGK_lab#debug voice en
IOSGK_lab#debug voice enum det
IOSGK_lab#debug voice enum detail
enum debug detail debugging is on
IOSGK_lab#
IOSGK_lab#test en
IOSGK_lab#test enum 1 0297796908
IOSGK_lab#enum_resolve_domain: match_num 0297796908 table_indx 1
enum_resolve_domain: rule 2 result string +61297796908
generate_enum_search_string : search string 8.0.9.6.9.7.7.9.2.1.6.e164.test
enum_dns_query: name = 8.0.9.6.9.7.7.9.2.1.6.e164.test type = 35, ns_server = 0
order 100 pref 10 service SIP+E2U flag u
regexp !^.*$!sip:61262112650@182.255.112.18! replacement
num_elem = 1
NAPTR Record : order 100 pref 10 service SIP+E2U
flags u regexp !^.*$!sip:61262112650@182.255.112.18!
replacement
decode_naptr_record : re_string ^.*$
decode_naptr_record : re_substitution_string sip:61262112650@182.255.112.18
decode_naptr_record : re_flags_string
U_FLAG case, stopping query
new_e164_user sip:61262112650@182.255.112.18
contact_list :
enum_resolve_domain: contact_list 69F802AC
contact_list :
enum_test_command: contact_list 69F802AC
IOSGK_lab#
IOSGK_lab#test en
IOSGK_lab#test enum 2 61297796908
IOSGK_lab#enum_resolve_domain: match_num 61297796908 table_indx 2
enum_resolve_domain: rule 1 result string 61297796908
num_elem = 1
replacement
contact_list :
enum_resolve_domain: contact_list 69F7FE84
contact_list :
enum_test_command: contact_list 69F7FE84
IOSGK_lab#debug ccsip mess
IOSGK_lab#debug ccsip messages
SIP Call messages tracing is enabled
IOSGK_lab#
*Aug 15 2012 13:20:52.943 AEST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0297796908@202.158.213.203:5060 SIP/2.0
Via: SIP/2.0/TCP 182.255.112.16:5060;branch=z9hG4bK5jtvut008gi10jot70g0.1
Call-ID: c1d35800-2b119d9-17955-23cf9eca@202.158.207.35
CSeq: 101 INVITE
Remote-Party-ID: "Bill Efthimiou" <sip:6952@202.158.207.35>;party=calling;screen=yes;privacy=off
Contact: <sip:6952@182.255.112.16:5060;transport=tcp>;video;audio;video
From: "Bill Efthimiou" <sip:6952@182.255.112.16:28954>;tag=1014027~968f888f-ba3a-4701-bd83-3fce8ea74ec4-33963081
To: <sip:+61297796908@202.158.213.203:5060>
Max-Forwards: 14
Allow: INVITE,OPTIONS,INFO,BYE,CANCEL,ACK,PRACK,REFER,SUBSCRIBE,NOTIFY
User-Agent: Cisco-CUCM8.6
Expires: 180
Date: Wed, 15 Aug 2012 03:39:05 GMT
Supported: timer,resource-priority,replaces,X-cisco-srtp-fallback,Geolocation
Session-Expires: 1800
Min-SE: 1800
Allow-Events: presence,kpml
X-TAATag: c3862244-e68a-11e1-a613-0010f316ecc8
Call-Info: <sip:202.158.207.35:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3251853312-0000065536-0000004605-0600809162
Content-Length: 0
*Aug 15 2012 13:20:52.951 AEST: //1295/C1D358000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 15 Aug 2012 03:20:52 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Aug 15 2012 13:20:52.955 AEST: //1295/C1D358000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: <sip:+61297796908@202.158.213.203:5060>;tag=A15BC8-2113
CSeq: 101 INVITE
Reason: Q.850;cause=3
Content-Length: 0
*Aug 15 2012 13:20:52.959 AEST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0297796908@202.158.213.203:5060 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 14
Content-Length: 0
Any guidance here would be greatly appreciated. Please let me know if any further details are required to diagnose this problem.
Bill
08-19-2012 05:23 AM
hi Bill,
cause of 3 ...indicates that the called party can't be reached . Are you able to ping the destination?
Could you include the following for me...
debug voip ccapi inout
debug ccsip all
(collect the above outputs in a buffer and copy/ upload the "sh log" in a clear text file to this post)
Karthik
08-19-2012 08:43 PM
Thanks Karthik,
I have uploaded the debug to the original post. I am not sure I'm reading the debug correctly, but looks like a possible codec issue:
*Aug 20 2012 11:26:45.797 AEST: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec: Unexpected VoIPCodec Type :No Codec
*Aug 20 2012 11:26:45.797 AEST: //22221/9D9BC0800000/SIP/Error/sipSPIAddSDPMediaPayload: Call Origination Failed: None of the selected codec from CLI is supported by SIP
*Aug 20 2012 11:26:45.797 AEST: //22221/9D9BC0800000/SIP/Error/sipSPIOutgoingCallSDP: Error with codec types on media line : 1
*Aug 20 2012 11:26:45.797 AEST: //22221/9D9BC0800000/SIP/Error/sipSPICreateOutboundSDP: Error in creating an SDP for the outbound call - Check for supported codecs
*Aug 20 2012 11:26:45.797 AEST: //22221/9D9BC0800000/SIP/Error/ccsipDoPostDNSAndENUMProcForInitialInvite: Error during deferred outbound SDP creation
*Aug 20 2012 11:26:45.797 AEST: //22221/9D9BC0800000/SIP/Error/sipSPIResolveFromContactList: ccsipDoPostDNSAndENUMProcForInitialInvite failed
Kind Regards,
Bill Efthimiou
08-19-2012 10:19 PM
hi Bill,
From the logs The cube has with reponded "404 Not found" cause =3 as ENUM query fails or not
resolved.
Hence the ENUM part of the config needs to be checked. I noticed some of the config is different from what is given in the doc . For eg. you have stated e.164.test when it should have been stated as e.164.arpa . Also check the DNS config.
Also on the CUCM set the "Stop Routing on Unallocated Number Flag to False" this will allow calls to completed even if ENUM query fails.
Hope this Helps!
Karthik
