Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
selecting second line for outgoing calls by default
when we make out going calls, i want to select second line by default. plz suggest me where i s the settings to be changed in call manager.
Baskaran.M
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
I dont think this is possible. There is no way to make the second line the primary line..AFAIK (as far as I know)
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
If you are using CME then you need to apply this command in your telephony-service configuration.
auto-answer answer-incoming
No. the problem is I'm using call manager. if I'm using CME it is the mnetioned commands works.
plz suggest for call manager. if i configure in phone button template as line 2 as NEW CALL will it work?
Baskaran,M
VIP Super Bronze
On the 89xx/99xx series phones, you can "select" a line, and that will be used as your primary line.
However, this is a user-initated action, not a configurable action from the back-end.
There is the logic, though, that if you always want all calls to go out on a particular line, why not make *that* the prime line on the phone...
GTG
Please rate all helpful posts.
997
