11-01-2013 04:55 AM - edited 03-16-2019 08:11 PM
I am currently using Cisco Call Manager 9.1.1
We have a director who wants all calls to be forwarded to his secretary. However, if a call comes through that the secretary wants to transfer to the director her number is also being caught in in the forwarding rule.
Is there a way of enabling selective call forwarding, or altering the rules to allow the secretaries DN to bypass the forwarding rule in place for all other numbers?
Apologies for the plain-english, I'm not well versed in CM.
Thanks in advance,
-David
Solved! Go to Solution.
11-01-2013 05:37 AM
Hi David,
+5 to my buddy Chris for his good tips!
I think Call Forward Override may be exactly what you need
Cisco Unified CallManager provides a service parameter (CFA Destination Override) that allows the administrator to override Call Forward All (CFA) when the target of the CFA calls the initiator of the CFA, so the CFA target can reach the initiator for important calls. In other words, when the user to whom calls are being forwarded (the target) calls the user whose calls are being forwarded (the initiator), the phone of the initiator rings instead of call forwarding back to the target. The override works whether the CFA target phone number is internal or external.
When the CFA Destination Override service parameter is set to False (the default value), no override occurs. Ensure the service parameter is set to True for CFA override to work. See Service Parameters Configuration in the Cisco Unified CallManager Administration Guide
Cheers!
Rob
"Why do the best things always disappear "
- The Band
11-01-2013 05:12 AM
No, but perhaps giving the secretary his number as shared extension would be better idea than call forward.
Chris
11-01-2013 05:37 AM
Hi David,
Cheers!
Rob
- The Band
11-01-2013 06:15 AM
Right on Rob, I did forget about this parameter :-)
Chris
11-01-2013 06:33 AM
Thank you both, I shall try this out.
CFA Destination Override fixed this problem. No more transfer loops. Yay!
Thank you.
