Send a specific number out local gateway
We have 20 locations and each one has a local gateway running h323 and POTS lines plugged into them.  I would like to send one specific number out the gateway locally at each location (4192671234).  I would like the users to be able to dial 74192671234.  The call will be a local call for some gateways and a long distance call for others.  How do I configure a Dial Peer specifically for this number that will let the users dial the number and not need to attach a 1 if they're dialing long distance.  I have my current Dial Peer config below.
dial-peer voice 1 pots
 destination-pattern 2601234567
 direct-inward-dial
 port 0/0/0
 forward-digits 0
 prefix 85000
dial-peer voice 2 pots
 destination-pattern 7[2-9].........
 port 0/0/0
 forward-digits 10
dial-peer voice 2000 voip
 preference 1
 destination-pattern .
 progress_ind setup enable 3
 session target ipv4:10.1.1.1
 incoming called-number .
 voice-class codec 99
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 fax rate disable
 no vad
dial-peer voice 5 pots
dial-peer voice 2001 voip
 preference 2
 session target ipv4:10.1.1.2
 voice-class h323 1
 fax rate disable
 no vad
dial-peer voice 3 pots
 destination-pattern 911
 port 0/0/0
 forward-digits 3
dial-peer voice 4 pots
 destination-pattern 7911
 port 0/0/0
 forward-digits 3
Everyone's tags (1)
You should start by
You should start by mentioning if this is CUCM or CME, and version.
java
if this helps, please rate
www.cisco.com/go/pdi
Sorry! CUCM 8.6. I guess I
Sorry! CUCM 8.6. I guess I was thinking about the gateway and not the call manager side. Thanks!
CSS / partitions and your
CSS / partitions and your dial plan define that (remove/prefix digits)
If they need to add the 1, configure a RP with the 1 they can reach, and make sure to have a matching DP
If they don't need to dial the 1, configure the RP without the 1, and the matching DP in the GW
java
35
