Send Only Mobile to one Dial Peer
Hello All,
My Solution have 2xCCM 4.2(PUB SUB) and 2x2851 Gateways running IOS 12.4-11.T2.
My problem is, I need to Identify the caller ID of PSTN Calls and send to one specific voip dial-Peer.
So the final result that I need to achive is:
PSTN CALL: CALLER-ID 83753337
Called number 8998
any Caller-ID that starts with 7,8,9 must match the dial-peer voip 10 that have a Session Target pointing to another Gateway.
And anything else must match dial-peer voip 11 or 12 that point to CCM.
Thanks in advance for all.
Hall of Fame Super Gold
Re: Send Only Mobile to one Dial Peer
This is call routing based on calling number.
As far as I know, CCM cannot do it, but the GW can, as long you are using H.323 and not MGCP to the CCM. Since you mention dial-peers, I think you can then do that. See following document:
http://cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
In short: match on answer-address pattern on incoming DP, set a "steering prefix", strip it out on the outgoing DP.
Hello, Thanks for your Help.
I see the document that you send, but what I need to do is something like that:
Here In Brazil, Mobile phone numbers start with 7,8 and 9. So when any call from PSTN that contains a caller ID starting with 7,8 or 9, need to get the Dial Peer 10, that is one gateway for Mobile numbers, and if the caller ID start with 2,3,4,5 and 6 the call need to match dial peers 11 or 12.
Here is what I thy:
dial-peer voice 10 voip
description ### Entrada PSTN QuesCom ###
preference 1
answer-address 118T
voice-class codec 1
session target ipv4:13.141.12.10
dtmf-relay h245-alphanumeric
dial-peer voice 11 voip
description ### Entrada PSTN CCM SUB ###
preference 2
destination-pattern 8...
voice-class codec 1
voice-class h323 1
session target ipv4:13.141.12.6
dial-peer voice 12 voip
description ### Entrada PSTN CCM PUB ###
preference 3
voice-class codec 1
voice-class h323 1
session target ipv4:13.141.12.5
Thanks again
Oi,
Yes, so you need to configure the incoming DP and (for clarity) a separate outgoing DP:
dial-peer voice 118 pots
description call from cellphones
answer-address 118...... <-- 7 digits following 8
translation-profile incoming add888
translation-profile outgoing strip888
destination-pattern 888........
voice translation-profile add888
translate called 880
voice translation-profile strip888
translate called 881
voice translation-rule 880
rule 10 // /888/
voice translation-rule 881
rule 10 /^888/ //
Thanks for your help, the solution that you send resolve the issue.
Tafari Lima
Thanks for the nice rating, and muita boa sorte!
Hi Paolo,
can You give me some help ?
I've a similar problem, but not for just a caller-id but also for a called-id.
I mean that I need that all international calls going to a certaint DN1 was redirected to DN2.
I tried with the answer-address, but it does not work.
Any suggest ?
many thanks
Luigi
Luigi, I'm not sure to understand. Can you make an example ?
Hi Paolo,
what I'll need is that just all incoming international calls to DN1 1234 was redirected to DN2 5678.
I've to intercept only international calls to a single DN. Is that possible ?
regards and many thanks
Luigi
What callamanager or express do you have, and what protocol do you have between gateway and callmanager, and what kind of lines to telco do you have ?
I've callmanager 4.3 with 2 gtw connected in H.323 and incoming calls via E1 ( one E1 for each gateway ). With a collegue of mine we was thinking about to configure a "dial-peer voip xxx voip" with for the DN requiring that configuration, and specifing on that dial-peer "dial-plan international".
By this way i would be able to intercept international calls to that DN using outgoing dial-peer.
We've still to test.
Luigi
Hi Luigi,
It may work as suggested, but I'm not sure.
You would first catch with "numbering-type international", on an incoming pots DP, that also has "incoming called-number" to be sure.
This DP also need have "translation-profile incoming XXX". In the translation-rule, for the called number you will prefix some digits in front of called, for the purpose of sending to a a specially selected outgoing DP, suppose the digits are FF.
rule 1 // /FF/
In fact you will have two ougoing voip DPs, one for all extension, destination-pattern FF.... (assume you have four digits extension). This one will have a translation-profile that only strips FF and leave the extensions as it has to be:
rule 1 /^FF/ //
Finally you will have the voip DP for the extension that doesn't receive international calls. This one, will match destination-pattern FF1234, and will have a translation-profile and rule that will set called number to be 5678.
rule 1 /^FF1234/ /5678/
The alternative to all the above, is a custom TCL/IVR script.
183
