Send pound sign (#) to sip trunk
I have a customer with a cme 8 that needs to send the special code #00 that connects to another system in a sip trunk.
I did a dial-peer with this destinattion-pattern like this:
dial-peer voice 30 voip
description ** #00 call **
destination-pattern #00
rtp payload-type nte 99
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711ulaw
The calls always fail
I did a "debug voip dialpeer all" and i found that the CME when i call the #00 it see the called number as: T00 and the dial-peer never match
How can i do to make this work?
If i use another special charactar like *00 it works, but is necesary the #00
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
IOS uses # as termination key, you can change that with following command:
dial-peer terminator A
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_d1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1114770
HTH,
Chris
HTH,
Chris
Hi Chris
This solve my issue
Thanks a lot
594
