Community Member
sending call to pstn using unity
hi
i have unity 4.0(5), i need to make calls sent directly to e.g 9xxxxxx(a mobile number) during 9am-3pm but after that i need the caller to leave a message
i have tried 2 ways for this
1-in the subscriber made in standard greeting , to go to subuscribers phone nuber , and put in the transfer part the pstn no,and in the closed greating i made it take message
2-creat a callhandler and send the after standerd greating to this handler where is transferd to pstn no
Bronze
Re: sending call to pstn using unity
In step 1, did you create a new schedule reflecting the 9-3 time so it will hit standard during open and closed during closed?
VIP Purple
You will need to modify the Restriction Table to allow transfer to an external number. Unity admin > Call Management > Restriction Tables.
Hope this helps.
Brandon
Hall of Fame Super Silver
Make sure your restriction table in Unity allows 9XXXXXXX access.
HTH,
Chris
Community Member
thank u all
yes i did allowed the pattern 9xxxxx
and it is working
but what i am thinking of is that it can be done in the subscriber without using the handlerm, an i wrong or missing somthing
141
