Community Member
Sending email using EEM to multiple recipients
I was looking for an article that explained how to send an email using Cisco's EEM to multiple recipients and couldn't find anything.  I figured it out for myself and figured I would share what I found.  Below is just a simple test script that sends an email to 2 recipients whenever the "Config" pattern is matched in Syslog:
event manager environment _email_to,
event manager applet test1
 event syslog pattern "Config"
 action 1.01 mail server "" to "$_email_to" from "" subject "Test1" body "This is a test!"
 action 1.02 syslog msg "Test email sent!"
Hope it helps someone else.
Everyone's tags (4)
Thanks for sharing your
Thanks for sharing your findings. It may surely help others.
Just a small suggestion, that you posted this as a question, and not as a document, which if you do will help others to find this more easily, being document.
You can try to move this as a Document or create another one as well.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Community Member
I was originally going to do
I was originally going to do this as a document, but discussions seem to be viewed a bit more and I thought a dialogue would be easier as a discussion versus a document.
