sending fax doesnt work, but recieving does
jjoseph01
Level 3
Level 3
Hi all, Im on a new install and have found that when I try to send faxes out, it doesnt work correctly. What I have is a 3825 gateway (MGCP) and CUCM 6.1.3. I have an FXS module in the gateway. I will recieve a call just fine to the fax, but when I put my analog phone on the fxs module to place a call as a test, I immediately get a fast busy signal before I can even dial any digits. TAC had me upgrade the IOS, which did not fix this issue. Anyone seen this issue before?
12 Replies 12
jjoseph01
Level 3
Level 3
By the way, its a BE server.
nwkotze
Hi, connect a analog phone to the FXS interface, see if:
- you get a dial-tone
- make a call
If not change the Voltage to High.
Also send me a "sho inv" and "sho ver"
Many Thanks, Nico
Yeah, I connected an analog phone up, thats how I knew that I was getting the fast busy. Im not sure how to change the voltage, I may need your advice on how to do that. See below for what you asked for:
term len 0
3825#sh inv
NAME: "3825 chassis", DESCR: "3825 chassis"
PID: CISCO3825 , VID: V05 , SN: XXXXXXXXXXXXXXXXX
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: XXXXXXXXXXXXXXXXXXX
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID= , VID: 3.1, SN: XXXXXXXXXXXXXXx
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: XXXXXXXXXXXXXXXXXXX
3825#sho ver
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 22:21 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
3825 uptime is 10 minutes
System returned to ROM by reload at 14:28:54 UTC Mon Jun 22 2009
System image file is "flash:c3825-spservicesk9-mz.124-24.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 489471K/34816K bytes of memory.
Processor board ID XXXXXXXXXx
2 Gigabit Ethernet interfaces
48 Serial interfaces
2 Channelized/Clear T1/PRI ports
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
Pls send me the "sho run"? - Nico
version 12.4
boot-start-marker
boot system flash:c3825-spservicesk9-mz.124-24.T.bin
boot-end-marker
card type t1 0 0
logging message-counter syslog
logging buffered 51200 warnings
enable password .
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
dot11 syslog
ip source-route
ip domain name ..com
no ipv6 cef
isdn switch-type primary-4ess
voice-card 0
no local-bypass
voice service pots
fax rate disable
archive
log config
hidekeys
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
interface GigabitEthernet0/0
ip address XXXXXXXXX 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description Voice Network
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXXXXXXxXXX
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/0/0:23
echo-cancel coverage 64
voice-port 0/0/1:23
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server XXXXXXXX
ccm-manager config
mgcp
mgcp call-agent XXXXXXXXX 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
dspfarm profile 1 conference
maximum conference-participants 0
shutdown
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address XXXXXXXXXX port 2000
max-ephones 336
max-dn 960
line con 0
line aux 0
line vty 0 4
privilege level 15
password .
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
Not sure the country you in but if you in the UK your FXS voice-ports should look like this, to add the cptone's:
do "cptone ?" - and select your country's tones, connect an analog phone, test and let me know.
voice-port 0/2/0
cptone GB
voice-port 0/2/1
cptone GB
voice-port 0/2/2
cptone GB
voice-port 0/2/3
cptone GB
In the US.
Just do: - test with analog phone and let me know...
voice-port 0/2/0
cptone US
voice-port 0/2/1
cptone US
voice-port 0/2/2
cptone US
voice-port 0/2/3
cptone US
voice rtp send-recv
voice service voip
modem relay nse codec g711ulaw gw-controlled
Justin
Hey guys, tried both, still get a fast busy when I pick it up.
ok, it was the "Prefix DN" on the DN of the FXS port. I had something put in there where there shouldnt have been. Thanks all.
Thanks guys for your participation and help.
