08-28-2013 05:57 AM - edited 03-16-2019 07:05 PM
What is required on the Callmanager side to integrate with the EXTENSION app?
How is text delivered to the Callmanager using the EXTENSION app?
Is it possible to send a text to mulitple 7925 phones at once? Like a distribution group?
Callmanager 9.1
08-28-2013 06:15 AM
If you're talking about a 3rd party app, they should have provided you with all the necessary info for the integration and you would need to ask them about the capabilibities, and how their product works.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-28-2013 06:32 AM
Yeah, it's a 3rd party app. A vendor is installing it along with our call manager, however they were not able to answer our questions. One party is managing the project and they have hired another vendor for the installation and the vendor that is handling the installation, was not in the meeting.
I'm trying to educate myself, so I know what questions to ask.
08-28-2013 08:19 AM
Generally speaking, third-party apps require an Application User account with either superuser CTI Manager access (i.e. all control of all devices) or the phones directly associated to the account. Alternatively, some applications - namely paging apps - want to replace the Authentication URL string to point at their server instead of CUCM so they can blindly authorize XML SDK requests from the phones.
The application will send an XML SDK call to the phone's IP address (which it may need to find out from another API on CUCM). The phone will ask the Auth URL to validate the request, and then execute the action. In many cases this is an HTTP URL that returns an XML-formatted document. This gets displayed as text.
That's up to the app that issues the XML SDK calls. It would need to issue a command to each phone it wants to broadcast the message to. There is no broadcast mechanism inherently because the API is within the phone itself, not in CUCM.
Please remember to rate helpful responses and identify helpful or correct answers.
