Community Member
SEP.cnf.xml for 9971
Hi Folks,
Does anyone have a working SEPxxxxxxxxxxxx.cnf.xml file for a 9971 that they could share the content of (suitably anonymised of course).
Many thanks
Sean
1 ACCEPTED SOLUTION
Re: SEP.cnf.xml for 9971
Sean,
See attached example.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Sean,
HTH.
Bill
Community Member
Many thanks Bill,
I'm trying to get the 9971 working with an open-source server, so any clues like this are appreciated.
Sean
Community Member
Hi!
Im having a problem with a cp 9971 phone.
it doesnt register because it keeps looking for the SEP file. I connected my laptop and with a tftp server tried to see what it actually wanted and it showed me that it looks for some files... CTLSEP.tlv, ITLSEP.tlv, ITLFILE.tlv, SEP.cnf.xml and XMLDefault.cnf.xml.
would you happen to know how to fix this??
if i copy the xml file you attached, what are the parameters i would have to change? im using a CUCM 8.6
i would appriciate it if u could help me out
thanks!
sincerely,
Dante Verastegui
3179
