SEP<MAC>.cnf.xml file needed for 3rd party PBX
alalli
Level 2
Level 2
Good Day All,
I need to generate an SEP<MAC>.cnf.xml file for a 3rd party PABX and a cisco 8961 phone.
Does anyone have a template for me to follow or a working cnf.xml file for this type of phone?
Thanks very much for any help
Amanda Lalli-Cafini
Yes, as long as the fields are formated properly, the phone should be able to download the firmware files.
If you want the exact format for the fields for a 89xx, I would advise grabbing the file from an existing CUCM
server.
-Felipe
8 Replies 8
Felipe Garrido
There are no example config files for the 89xx series phones. Closest thing available is for the 7960/40.
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cuipph/7960g_7940g/sip/8_0/english/administration/guide/sipins80.html
If you have access to one, another idea would be to pull the file directly from CUCM.
-Felipe
Hi Felipe,
Thank you for the reply.
I have read the document and am now trying to get the Cisco Phone to register with a Call Manager version 7.0.2 edition.
This phone is so new that it is now showing up in the phone lists.
If I were to find and download the phone firmware and store that on the Call Manager,  would I then be able to load the phone?
thanks for any help.
Amanda
Hi Guys,
I have found a .cnf.xml file and am hoping to use it with the new Cisco 8961.
It was a file taken from a CME router.
My hostname is SEP1C17D340F2C2 so I will change the name of the file to suit.
I have replaced the extension number and extension number password.
I have listed the IP PBX server as the call processor.
I am not sure what to put into the load version area of the file.
Does anyone have an idea what to do with this?
<loadInformation />
<versionStamp>0000548728212372versionStamp>
My load info is sip8961.9-0-0-77
Does anyone know if I can get away with modifying this old file and also what to do with the loadinformation?
I could also remove that line from the file and let the phone boot the image it has.
Any additional ideas please?
Thanks so much,
Amanda Lalli-Cafini
You'll need to upgrade the CUCM to 7.1.3 or later to have it support the 89xx phone type.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10451/ps10511/data_sheet_c78-565397.html
-Felipe
OP has CME, not CM.
At present time, CME does not support these phones.
OP is actually trying to get these to register to a 3rd party PBX. They only pulled the SEPxxx.cnf.xml file from a CME.
-Felipe
Hi Guys,
The file I am using is for a completely different model number.
I am hoping to rename the file to the MAC address of the phonel and to alter the load on the file.
My file contains a section followed by a versionStamp /versionStamp.
I hope to remove the information in the versionStamp and let the phone simply boot the image it currently has.
In theory,  I think the phone should be able to download this file from the third party PABX.
What do you think,  is it worth a try or is it something that I probablly should not do.
Thanks very much for any help.
Amanda Lalli-Cafini
<loadInformation />
- <userLocale>
<name>English_United_Statesname>
<langCode>enlangCode>
userLocale>
<networkLocale>United_StatesnetworkLocale>
- <networkLocaleInfo>
<name>United_Statesname>
networkLocaleInfo>
<authenticationURL />
<directoryURL />
<servicesURL />
<transportLayerProtocol>2transportLayerProtocol>
device>
server.
-Felipe
