Separating outgoing calls for different extensions on CME
Hi All.
I'm experiencing some problem configuring outgoing dial-peers on C2801 CME4.2. There is one BRI line, and I want only one extension to use BRI line1 only for outgoing calls and show this outgoing number (Caller id 1). The rest of extensions should use BRI line2 only for outgoing calls and show this outgoing number (caller id 2). Is it possible to separate like that?
Thanks in advance.
Hall of Fame Super Gold
Re: Separating outgoing calls for different extensions on CME
There are many threads on the subject, have you tried searching ?
Of course I did. I haven't found anything for my case specifically. Maybe somebody has CLI commands handy, so I can review and apply them.
111
