Serial Number on MCS servers
Hi all,
I've got 9 MCS servers on various sites that I need to find the serial numbers of.
I've go CM6.1 running on 7 of them and Unity 5 on Win 2k3 on the 2 others.
Any ideas how I can do this remotely? I can't seem to get them to share the info with me!!
LH
1 ACCEPTED SOLUTION
Re: Serial Number on MCS servers
Hi there Adrian,
That's worked a charm for the Windows servers, but when I run the snmp commands on the ccm cli I get no response, but the server promises me it's running snmp:-
admin:utils snmp walk 2c public 127.0.0.1 .1.3.6.1.4.1.232.2.2.2.1.0
This command may temporarily impact CPU performance.
Continue (y/n)?y
Failed :
Timeout: No Response from 127.0.0.1
Executed command unsuccessfully
admin:
admin:
admin:utils snmp test
Service Manager is running
Test SNMP Trap starts with Local Host Name, Specify a Remote Sever Name to test Remote Syslog
Message from syslogd@publisher at Thu Apr 2 16:15:03 2009 ...
publisher local7 0 : 1: Apr 02 15:15:03.8 UTC : %CCM_CALLMANAGER-TESTALARMCATALOG-0-TestAlarmEmergency: Testing EMERGENCY_ALARM App ID:Cisco CallManager Cluster ID: Node ID:publisher
Message from syslogd@127.0.0.1 at Thu Apr 2 16:15:03 2009 ...
127.0.0.1 local7 0 1: Apr 02 15:15:03.8 UTC : %CCM_CALLMANAGER-TESTALARMCATALOG-0-TestAlarmEmergency: Testing EMERGENCY_ALARM App ID:Cisco CallManager Cluster ID: Node ID:publisher
TestAlarmInformational sent [Returncode=0]
TestAlarmEmergency sent [Returncode=0]
TestAlarmAlert sent [returncode=0]
TestAlarmCritical sent [Returncode=0]
TestAlarmDebug sent [Returncode=0]
TestAlarmNotice sent [Returncode=0]
TestAlarmWarning sent [Returncode=0]
TestAlarmError sent [Returncode=0]
admin:
Any thoughts?
LH
Hi Leigh
If you have a MIB Browser application you could use this SNMP OID - .1.3.6.1.4.1.232.2.2.2.1 cpqSiSysSerialNum - Description: "The serial number of the system unit."
I hope this helps.
Michael
673
