07-01-2013 07:11 PM - edited 03-16-2019 06:10 PM
Hi all,
I am using CUCM version 7.1. After I install subscribers, I can not start any services in Sevice Activation page. The publisher is ok. Error message:
"...Service cannot be Activated or Deactivated due to Database Update Failure".
Any ideas for me.
07-01-2013 08:34 PM
Hi Thuc,
What is the exact CUCM version u are using?
can u share the output of utils dbreplication runtimestate or from Cisco Unified Reporting , shgare DB status report?
regds,
aman
07-01-2013 09:07 PM
I am using version 7.0.2.10000-18. Out put of utils dbreplicate status:
admin:utils re
utils remote_account
utils reset_ui_administrator_name
utils reset_ui_administrator_password
admin:utils db
admin:utils dbreplication
utils dbreplication clusterreset
utils dbreplication dropadmindb
utils dbreplication forcedatasyncsub
utils dbreplication repair
utils dbreplication reset
utils dbreplication setrepltimeout
utils dbreplication status
utils dbreplication stop
admin:utils dbreplication st
admin:utils dbreplication stat
admin:utils dbreplication status
This command reads and writes database information from all machines and will take quite some time...please be patient.
-------------------- utils dbreplication status --------------------
Output is in file cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_11_05_56.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_11_05_56.out " command to see the output
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_11_05_56.out
connect to cucmsub1_ccm7_0_2_10000_18 failed
Enterprise Replication not active (62)
command failed -- unable to connect to server specified (5)
No Errors or Mismatches found.
Replication status is good on all available servers.
utils dbreplication status output
To determine if replication is suspect, look for the following:
(1) Number of rows in a table do not match on all nodes.
(2) Non-zero values occur in any of the other output columns for a table
connect to syscdr@cucmsub1_ccm7_0_2_10000_18 failed
Error Details:
options: q=quit, n=next, p=prev, b=begin, e=end (lines 1 - 20 of 32) :
admin:
Thuc
07-01-2013 09:25 PM
Hi Thuc,
Please refer the link for resolving DBReplication problem.Was this working earlier or faced the replication problem now
https://supportforums.cisco.com/docs/DOC-13672
From Cisco Unified Reporting , can u share the snapshot of CM Database Status report.
regds,
aman
07-01-2013 09:38 PM
Please review screen capture for DB reporting:
Thuc
07-01-2013 10:08 PM
Hi Thuc,
It seems that you have three servers in a cluster out of which two Subscribers are facing the issue of DBReplication.
Can u try the commands to fix the issue.
You won't be able to use utils dbreplication rumtimestate. So, use Cisco unified reporting tool to check the Count.It should be 2 if replication is fine.[Expand View details]
regds,
aman
07-01-2013 10:45 PM
Hi Aman,
Thanks for help.
I tried to fix DB replication issue. But I still can not activate any services.
Output is in file cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_12_36_13.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_12_36_13.out " command to see the output
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_12_36_13.out
SERVER ID STATE STATUS QUEUE CONNECTION CHANGED
g_cucmpub_ccm7_0_2_10000_18 2 Active Local 0
g_cucmsub1_ccm7_0_2_10000_18 3 Active Connected 0 Jul 2 11:32:03
command failed -- undefined replicateset (11)
Error Details:
The specified replicate name does not exist.
options: q=quit, n=next, p=prev, b=begin, e=end (lines 1 - 20 of 26) :
admin:
I also resintalled one subscriber with same IP address and Hostname. It is working fine. The other one is kept troubleshooting.
How about the log file to diagnose the activation issue? Could you suggest for me?
Tha
07-01-2013 11:25 PM
Hi Thuc,
Was this working setup ?
Hope u have enough Node Licenses on Call manager and u have added SUb2 in Pub.
regds,
aman
07-01-2013 11:52 PM
Hi Aman,
I checked the license report:
With rebuilded subscriber server, now I can activate the services.
Thuc
07-02-2013 12:03 AM
Hi Thuc,
Thanks for update.
Finally , u had to rebuild both the subscribers.
regds,
aman
07-02-2013 12:16 AM
Hi Aman,
So, I want to find why I can not activate the services. Could you suggest me for log trace or debug or something like that?
Thuc.
07-02-2013 01:06 AM
Hi Thuc,
Now, since u have re-installed SUB, u won't be able to get the logs.
regds,
aman
07-02-2013 01:08 AM
I just rebuilded one subscriber server. The other is still there. We can get the log files if we want.
Thuc
07-02-2013 01:13 AM
Hi Thuc,
I thought u have rebuilt the second SUB as well.
Please follow the link to enable traces.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
regds,
aman
07-02-2013 01:15 AM
Hi Thuc,
Please provide the snapshot from
Cisco unified reporting tool -> Database Status -> Replication Server List
regds,
aman
