Community Member
Service Cisco Call Manager down
Hi Netpro
After the upgrade from 4.X to 6.1(2) with a database exported through the DMA tool, a procedure that will end with no errors, were loaded files respective licenses and services were activated, but the service Cisco Call Manager then you got to changes in state Started Not Running after a couple of minutes.
And resources ANN, MTP, CFB are not register in the CUCM 6.1(2)
fixie rider
Green
Re: Service Cisco Call Manager down
Make sure you have both Node and SW Feature License.
For the MTP, ANN and CFB, first check that IPVMS service is activated.
We had some bugs for that which require DB acccess to delete-re add Media Resources
Community Member
Thanks for your anwser
The license file it generated by TAC case and have the license for nodes.
I have all the services activated and start, only have problems whit Call Manager service
IPVMS = Cisco IP Voice Media Streaming App ???
fixie rider
Green
We need Software feature License.
Yes IPVMS = Cisco IP Voice Media Streaming App
If its activated and still devices not registering you may open a TAC case and reference this DDTS: CSCsk99120
183
