Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
service clid_authen_collect anable in CME 7.0
I have enable PIN option as is shown but sometimes after dialing the phone number the prompts which ask the user and PIN is not listen and the call goes through.
how can I check the reason the user and PIN is not asked?
application
param uid-len 3
param pin-len 3
username 369 password 7 091F1850
dial-peer voice 202 pots
corlist outgoing Cell
description Cellular Calls
destination-pattern 9044..........
direct-inward-dial
port 0/2/0:1
prefix 044
dial-peer voice 1202 voip
description Cellular Calls con PIN
session target ipv4:10.10.10.1
incoming called-number 9044..........
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
1 REPLY
Silver
Re: service clid_authen_collect anable in CME 7.0
Check the bug:
CSCsb50678: Authorization not done at GK for All Level Security
1018
