Service & Enterprise Parameters are not listed
mrfcisco1
Hi i am using CUCM 7.0 and i logged in as administrator. But i  am not able to set Service and Enterprise parameters. Parameters are not listed under these menus. Can any one please help me on this ?
9 Replies 9
Gajanan Pande
Shalu,
Could you share a screenshot of what you are seeing there ?
GP.
Are you loging in as the master admin user account or your own username, if the second what cm groups are you assigned to?
Chris
Hi Chris,
I am using master administrator account..
Please try "run loadxml " command, this command should resolve your issue.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak I will try and let you know the result. Now waiting for the approval to run the command.
For more details
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b2e113.shtml
Hi Gajanan Pande, Kindly find the attached screen shot..
Also you can upgrade your CUCM to latest device pack. And issue might get resolved.
This is how is done in below problem
https://supportforums.cisco.com/message/3585794#3585794
Ronak Patel
