service mgcp command
I just wanted to confirm that the service mgcp command in the pri-group timeslots command is automatically created when the command ccm-manager config is entered.
I had manually added and removed the service mgcp command on a e1 controller interface.
After do a no mgcp and mgcp, I could see the config download but the service mgcp command was never created.
Any comments appreciated.
Thank you.
Paul
1 REPLY
Re: service mgcp command
No, it's not automatically added.
You can refer to MGCP config guides and even they might tell you to add ccm-manager config you need to add the service mgcp under controller manually.
java
if this helps, please rate
java
www.cisco.com/go/pdi
286
