Service Provider SIP TRUNK & EXCHANGE 2007 AA no Ringback for PSTN Callers
I have a SIP Trunk from my Service Provider Terminated on my Cisco 2811 VG
calls are coming fine to DID Numbers (rining answering everything)...
I have CUCM 5.1 with a SIP Trunk to Exchange 2007 AA
when I call from internal extension I am hearing ringback even when the AA is transfering me to the extension that I have entered
but when I call from PSTN to the AA Number although the call is answerd by AA & DTMF is working fine but I am not hearing any ringcack in the PSTN side?!?!?!?
the calls are answerd & I can enter the required extension & hearing the Exchange telling okay calling the extension then nothing after that while the enterd extesion is ringing.....
I have MRGL for both GW & SIP Trunk to Exchange
Announciator & MTP are there
H225 Service parameter is set to (use announciator for ringback)
inbound & outbound fast start are enabled in the GW
latest IOS in the GW
progress-ind enable setup 3 has been tried in the VOIP Dial peer (incoming & CUCM)
Appreciating your kind support
Cheers....
236
