Service script answer on all dial-peers
marco
This is a basic question.
We've a router with a VIC2-2BRI interface.
If I configure the ports like this:
voice-port 2/0
translation-profile incoming filter1
output attenuation -5
compand-type a-law
timeouts interdigit 2
connection plar 200
bearer-cap Speech
voice-port 2/1
compand-type a-law
connection plar 400
bearer-cap Speech
dial-peer voice 1 pots
destination-pattern 0T
direct-inward-dial
port 2/0
dial-peer voice 2 pots
direct-inward-dial
port 2/1
everything works right; If I call the telephone number associated to the first BRI ISDN port the telephone associated to the 200 number rings and if I call the telephone number associated to the second BRI ISDN port, the telephone associated to the 400 number rings.
The problem is this: if I enable the "service" command on the "dial-peer voice 2 pots", the service doesn't "answer" at all.
service script1
direct-inward-dial
port 2/1
And If I enable the service command on the first dial-peer "dial-peer voice 1 pots" it answer to all the lines!
Can you help me in order to make the service answer only to the first voice port?
Thanks.
paolo bevilacqua
Which IOS? Have you tried using "incoming-called number" into the dial-peers?
Hope this helps, if so please rate post!
paolo bevilacqua
Thanks a lot, it works!
Marco.
Thank you for the rating. See:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic12
At some point in the above document, you will read:
Step 4 (voice-port) is not applicable to voice or dial platforms such as AS5300, AS5350, AS5400, AS5800 and AS5850
I think that because BRI is a digital port, it falls into the case above.
