03-17-2007 03:38 AM - edited 03-14-2019 08:31 PM
This is a basic question.
We've a router with a VIC2-2BRI interface.
If I configure the ports like this:
voice-port 2/0
translation-profile incoming filter1
output attenuation -5
compand-type a-law
timeouts interdigit 2
connection plar 200
bearer-cap Speech
voice-port 2/1
compand-type a-law
connection plar 400
bearer-cap Speech
dial-peer voice 1 pots
destination-pattern 0T
direct-inward-dial
port 2/0
dial-peer voice 2 pots
direct-inward-dial
port 2/1
everything works right; If I call the telephone number associated to the first BRI ISDN port the telephone associated to the 200 number rings and if I call the telephone number associated to the second BRI ISDN port, the telephone associated to the 400 number rings.
The problem is this: if I enable the "service" command on the "dial-peer voice 2 pots", the service doesn't "answer" at all.
service script1
direct-inward-dial
port 2/1
And If I enable the service command on the first dial-peer "dial-peer voice 1 pots" it answer to all the lines!
Can you help me in order to make the service answer only to the first voice port?
Thanks.
Solved! Go to Solution.
03-17-2007 04:56 AM
Which IOS? Have you tried using "incoming-called number" into the dial-peers?
Hope this helps, if so please rate post!
03-17-2007 04:56 AM
03-17-2007 06:25 AM
Thanks a lot, it works!
Marco.
03-17-2007 06:54 AM
Thank you for the rating. See:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic12
At some point in the above document, you will read:
Step 4 (voice-port) is not applicable to voice or dial platforms such as AS5300, AS5350, AS5400, AS5800 and AS5850
I think that because BRI is a digital port, it falls into the case above.
