Setting outbound pots dial-peers
Hi All,
I have 2 sites which use the same voice router. One site uses SIP, the other ISDN. The sites have different number ranges.
I've found out that they are both using the SIP trunk for their outbound calls and I need to force one site to use the ISDN line.
I was thinking to select dial-peer based on calling number, but can't see  from the dial-peer configuration how to do that.
Any help appreciated.
  • IP Telephony
Everyone's tags (1)
Using an ISR running 15.01
Call control?? Version??
java
if this helps, please rate
www.cisco.com/go/pdi
CUCM 7.1.5
CUCM 7.1.5
Simply set a prefix to
Simply set a prefix to distinguish how to route the calls.
destination-pattern 9.T for SIP
destination-pattern 2229.T for ISDN
Since POTS DPs drop exact matches, you'll match the right DP, and drop the extra digits, this has been discussed plenty of times at CSC.
java
Hi.To route calls based on
Hi.
To route calls based on calling number, you can use answer address on a voip diaper and then apply a translation profile to that DP.
Eg.
Calling number range 5100 - 5199
Destination - POTS (eg. ISDN E1 link)
voice translation-rule 10
rule 1 /^.*/ /1070\0/
voice translation-profile OUT-PSTN
translate called 10
dial-peer voice 10 voip
answer-address 5...
translation-profile incoming OUT-PSTN
dial-peer voice 20 pots
destination-pattern 1070T
port x/x/x:15
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks but I can't get this
Thanks but I can't get this to work. I've even disabled the SIP dial-peer but still can't get any call to go out the ISDN line.
Calls can come in fine, thanks god, just nothing goes out
Hi.Please send your VG conf
Hi.
Please send your VG conf and I'll suggest you the correct config.
Carlo
78
