Setting Up a primary/slave CM 7.0 server
I have to prepare my self to do a implementation at a customer who has two CM 7.x servers.
I have to make one of them as primary in Site A and the other one as secondary in Site B.
To do this I have read the CIPT 1 & 2 manuals, but didn't found anything to help me.
Now I run both CM 7.x in VMware and are fresh instalation.
Can u guys guide me how to do that???
Thanks in advance,
Michael
Re: Setting Up a primary/slave CM 7.0 server
Easy task, configure CUCM groups
Cisco Unified Communications Manager Group Configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b02cmgrp.html
Once you have the right groups assign them to Device Pools and use them for the phones.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for you're quick reply.
When I installed the second CM 7.x, when I was prompt to select if is the first node in network, I choosed that is not the first node. Is ok like this, because I don't have web access to this server.
That's a whole different thing, that's to define if you're installing a PUB or a SUB.
java
java
112
