mx
Setting up Attendant console
Hi. I have never set up an attendant console and am having problems finding out how to do it online. I find some cisco pdf's that reference it but none specifically how to set up call manager for it and the PC, installing the app etc. This is for cm 6.0.1 and Unity Unified 5.0. Maybe Im putting in the wrong search criteria?
Thanks for pointing me in the right direction.
Bob
Silver
Re: Setting up Attendant console
The attendant console installs on a PC with IP connectivity to the Cisco CallManager system. The attendant console works with a Cisco IP Phone that is registered to a Cisco CallManager system. Multiple attendant consoles can connect to a single Cisco CallManager system.
The application registers with and receives call-dispatching, login, line state, and directory services from the Cisco Telephony Call Dispatcher (TCD) service.
http://cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_0_1/ccmcfg/b04ccmac.html
Attendant Console
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/apps.html#wp1044119
BTW
under CUCM 6 there is no TCD, it's Cisco CallManager Attendant Console Server
java
if this helps, please rate
www.cisco.com/go/pdi
I created the attached document for some of my previous customers, hopefully it will be useful for you.
Hope it helps.
//Jorge
216
