Setting up CDR records
I am new to CDR and and trying to set it up to get an idea of how many calls are occuring over the LAN and over trunks. I set up CAR and logged into the interface, but I am not pulling any records.
What parameters do I need to set up to start compiling records of numbers called?
Also, I set up CDR on my unclassified network, but wheneven I try to login to ART, it can't find the webpage. I restarted the WWW service and IIS, but still no luck, any ideas?
Everyone's tags (3)
1 REPLY
Re: Setting up CDR records
Hi Micahel,
These should help you,
Setting up CDR -  http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_0_1/ccmsrva/sacdrm.html
Parameters you need to set - Click here to download the file
Common problems in CDR - Click here
Thomas Dominic
P.S. - Please rate helpfull posts
460
