Silver
Setting up Custom Call Handlers from Scratch on Unity 5.0
I have a fairly customized requirement to setup AA on Unity 5.0. Most of the rules end up routing to a specific extension. Currently Unity is setup for VM only.
Any configuration examples or things to look out for would be appreciated such as what if a invalid key is selected?
thanks in advance
Ajaz
Re: Setting up Custom Call Handlers from Scratch on Unity 5.0
An AA are just call handlers and caller input settings so there is nothing difficult on creating one
Unity Voicemail: Repeat the Same Greeting when an Invalid Key is Pressed
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_configuration_example09186a00806557c6.shtml
java
if this helps, please rate
java
www.cisco.com/go/pdi
Silver
Hi Java (nice name :)
any info on switching to night service etc, and how/where to allow a user to do this?
-Ajaz
That is the same as with any subscriber, configure the schedule and std/closed greetings so they activate as needed.
java
java
Silver
Java,
ok that's fine - I have another qtn. In terms of routing the call to unity and unity to recognize that a call handler must be initiated, what is the order and configuration tasks to be completed?
As i've stated - currently the setup is default for vm only. CTI route points have been configured for this and there are a total of 96ports. I need to be sure that any changes which I make do not impact the vm functionality as this is a production system :)
tia
Ajaz
A) Configure CTI RP with CFA and define the call handler using that DN
B) Same as above but use routing rules instead of DN
java
java
Silver
Java
Apologies but I didn't quite get what you meant here:
Are there any config guides which can be used to perform the required tasks?
thanks dude
Ajaz
134
