Community Member
setting up data and voice vlan
Hi Gurus,
We just finished setting up a small office network. Our ISP will supply the phone system however they want that we reconfigure network for a vlan to separate the data and voice lines. We would like to start a separate data/voice vlan for LAN and Wireless.
We have a 851W router and two 2950 Cat switches and the phones would be Nortel BMC/ip phones. Our DHCP and DNS are set up on
a domain server/domain controller. We are newbies to vlans and ip phones.
We would like to know what is the best practice to set up the data and voice vlans. Any configuration examples are welcome especially with Nortel phone system to us get started. We have general idea on how the vlan work but we have no confidence in configuring such as assigning ip addresses to its corresponding ports.
TIA.
Rob
Re: setting up data and voice vlan
on the 851 router you will need to setup sub interfaces. for example 0/1.10 0/1.20. You will also have to trunk these interfaces.
on the switches you will need to setup a normal data vlan lets say vlan 10 and also an auxillary vlan for voice lets say 20.
You will need to trunk down to the phones since they are Nortel and won't use CDP. There should be some way on the Nortel phones to choose which vlan to use. Please let me know if you have any questions.
Hall of Fame Super Gold
We you have't quite finished yet....
you need to setup the vlans, routing as necessary, the new DHCP pools on the server...
Are the PC daisy chained to the phones, or use independent ports ?
Unless you are determined technicians willing to learn and suffer, I suggest you contact a qualified cisco reseller that can help you in setting all this...
Community Member
Thanks guys.
Got something from you advice however
the 851w doesn't support multiple vlans.
I had everything set up on the swicthes
but got this problem with the 851w.
Rob
what software are you running on the 851? Show version will tell you.
From this link:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_qanda_item0900aecd8028a982.shtml
It appears that you need Advanced IP Services image, the standard Advanced Security does not support VLANs
Hope this helps, if so please rate post!
Community Member
Please find attached show version.
The link is useful.
Thank you
I need to correct myself, you have an 850, not an 870, that according to the documentation, only supports "one 802.1q VLAN". In practice, you can't route between VLANs using this small router. I don't think this will make any issue in practice, with one VLAN everything should work fine anyway.
319
