Setting up gateway - 2651XM PRI - no ISDN option Serial interface
I have a 2651XM running c2600-is-mz.122-15.T5.bin IOS.
It has the following hardware and software:
Primary Rate ISDN software, Version 1.1.
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
2 Channelized T1/PRI port(s)
2 Voice FXO interface(s)
2 Voice FXS interface(s)
I have configured the T1 card as:
controller T1 0/0
framing esf
clock source internal
linecode b8zs
cablelength short 133
channel-group 23 timeslots 24
However, when I go into the Serial 0/0:23 interface there are no "ISDN" commands. I want to set up the ISDN switchtype and setup the ISDN Bind-13 ccm-manager command.
Am I missing something?
Here is my running config:
Current configuration : 1860 bytes
version 12.2
service password-encryption
hostname testdialSBC
logging queue-limit 100
enable secret xxx
clock timezone cst -6
ip subnet-zero
ip tcp synwait-time 13
ip cef
isdn switch-type primary-ni
no voice hpi capture buffer
no voice hpi capture destination
ccm-manager redundant-host 10.10.14.56
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.14.56
ccm-manager config
mta receive maximum-recipients 0
controller T1 0/0
framing esf
linecode b8zs
controller T1 0/1
shutdown
framing sf
linecode ami
interface FastEthernet0/0
ip address 10.10.14.41 255.255.255.0
speed 100
full-duplex
interface BRI0/0
no ip address
shutdown
isdn switch-type basic-5ess
interface Serial0/0:23
no ip address
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.14.1
call rsvp-sync
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
mgcp
mgcp call-agent 10.10.14.58 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0
sccp
sccp ccm 10.10.14.58 priority 1
sccp ccm 10.10.14.56 priority 2
dial-peer cor custom
line con 0
password xxx
login
line aux 0
line vty 0 4
password xxx
login
end
Thanks in advance for any repsonses.
JP
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Setting up gateway - 2651XM PRI - no ISDN option Serial inte
Hi, which exact hardware do you have ? Do "show diag" to know. Not all HW supports PRI voice.
channel-group 23 timeslots 24 is for DATA
you need pri-group timeslost 1-24 service mgcp
if you search in CCO you will find several guides on how to configure this
Gateway Protocols
Configuration Examples and TechNotes
http://www.cisco.com/en/US/tech/tk1077/tech_configuration_examples_list.html
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for the quick response . .
However, when I go to the controller t1 1/0 interface I do not have that command option.
Do I need to upgrade my IOS?
JP
12.2 is pretty old, also make sure you have voice services on the IOS
javalenc
java
Here is the show diag:
Slot 0:
C2651XM 2FE Mainboard Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
PCB Serial Number : JAD06510CU8 (1423307700)
Part Number : 73-7756-02
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
Product (FRU) Number : C2651XM-2FE
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 6F 41 01 00 C1 18 4A 41 44 30 36 35
0x10: 31 30 43 55 38 20 28 31 34 32 33 33 30 37 37 30
0x20: 30 29 82 49 1E 4C 02 04 00 81 00 00 00 00 42 41
0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
T1 (2 port) WAN daughter card
Hardware revision 1.0 Board revision F0
Serial number 33331845 Part number 800-04477-03
FRU Part Number WIC/VIC-T1,DUAL=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 22 01 00 01 FC 9A 85 50 11 7D 03 00 00 00 00
0x30: 78 00 00 00 05 03 03 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
BRI U - 2091 WAN daughter card
Hardware revision 4.0 Board revision B0
Serial number 14690921 Part number 800-01834-02
FRU Part Number WIC-1B-U=
Connector type Wan Module
0x20: 01 09 04 00 00 E0 2A 69 50 07 2A 02 00 00 00 00
0x30: 58 00 00 00 99 06 23 01 FF FF FF FF FF FF FF FF
Slot 1:
4 PORT Voice PM for C2600 Port adapter
Port adapter is disabled
Hardware revision 1.1 Board revision D0
Serial number 13922808 Part number 800-02491-02
FRU Part Number: NM-2V=
0x00: 01 65 01 01 00 D4 71 F8 50 09 BB 02 00 00 00 00
I have downloaded multiple IOS' with no luck. Still no PRI-group timeslots 1-24 service MGCP on the controller or ISDN commands on the serial interfaces.
Jeff
you would need either AIM-VOICE30 or an NM-HDV-xx to enable the VWIC for voice. The latter is recommended as it it newer technology with the PVDM2 modules.
Currently you have no DSP resources in the the router to do that.
Please remember to rate useful posts.
627
