Community Member
Setting up multiple 2851 gateways in CM 4.1
We have 20 locations that each have a 2851 router that is used only for SRST and 911. Is there a way to import those using BAT, because its very tedius to do that one at a time?
Re: Setting up multiple 2851 gateways in CM 4.1
sorry, not possible with BAT
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
aw that sucks, thanks for the reply though :)
124
