Community Member
Setting up UCM6.1.3 with only UCM4.1.3 configuration
Running UCM 4.1.3.  Setting up a new UCM 6.1.3 cluster with a new hardware with required new node & DLU's for IP Phones.
To avoid reconfiguring in the new UCM 6.1.3,is it any way to put the existing UCM 4.1.3 configuration on new UCM 6.1.3 ??
Note:We are not doing upgradation from 4.1.3 to 6.1.3.
Thanks & Regards,
Krishna
Re: Setting up UCM6.1.3 with only UCM4.1.3 configuration
DMA would be the best way to migrate your data from 4.1.3 to 6.1.3
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/dma/6_1_3/dma-rel_note-613a.html
- Sriram
If you're not going to use DMA then your only choice is:
a) for licensing get in touch with licensing (licensing@cisco.com) so they can help you migrate DLUs and node licenses.
b) for config use DMA to get as much info as you can
Since the files and the format are not the same you cannot just pull the files from 4.X and insert them in 6.X without modifying them to adjust any of the new fields 6.X has as mandatory.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Hi Java,
Thanks for the reply.
If i am wrong pls correct me..
I wlil use the DMA backup (from UCM 4.1.3) during the installation of new UCM 6.1.3,then i will generate the license from the new PAK's (node & DLU)for node and DLU's.
pls reply back..
Reagrds,
Krishna
Once you start CUCM you will run on a temporary license, you need to submit this license in order to make it permanent. It will give you enough DLUs and node licenses for the config you had in 4.X.
in the license page in the bottom there is a migration license option you'll need to use.
What you'll need to register is the PAK for the feature license which you'll need to upload in order to start the ccm service.
java
java
152
