Bronze
Setup IP Phone to NetMeeting Phone Call
What is the easiest way to place calls from NetMeeting to a Cisco IP Phone? What hardware and/or software configuration that is necessary? I have a CallManager 4.1(3) server, a Unity 4.0(4) server and a Cisco 2621XM Router. Thanks!
Re: Setup IP Phone to NetMeeting Phone Call
Mike,
The easiest way to set this up is to configure the PC running NetMeeting as an H.323 Client / Endpoint within Call Manager.
Bronze
So how do you add the PC as a H.323 client/endpoint in CallManager? Thanks for the quick reply!
Here are the instructions for configuring Netmeeting in CallManager:
Step 1 Open Cisco CallManager.
Step 2 Select Devices > Add a Device.
The Add Device page displays.
Step 3 Select Device Type > Phone >Next
Step 4 Select the appropriate model from the Model drop-down list. In this case you need to select H.323 Client> Next A new window will be displayed
Step 5 In Device Name put the ip address of the PC or laptop that has the Netmeeting.
Leave other parameters as default and click Insert.
Step 6 Click an unassigned line (Line 1, Line 2, and so on).
A new window will be displayed.
Step 7 In Directory Number put the extension for the Netmeeting device.
Leave other parameters as default and click Insert and Close.
Follow these step in the NetMeeting Client:
Step 1 Go to Tools>Options.
In the General section click the Advanced Calling button that is located at the bottom.
A New window will be displayed.
Step 2 In the Gateway Settings section select "use a gateway to call telephones and videoconferencing systems" In the Gateway field put the IP address of the CISCO CALLMANAGER SERVER.
Click Ok>Ok.
Bronze
Would I need to setup an h.323 Gateway on my CallManager server? Sounds like a dumb question, but I'll ask any way!
174
