Setup phones to get an outside operator
How do I setup my phones so that users can get an outside operator. When I say outside operator I mean at&t operator.
Re: Setup phones to get an outside operator
CUCM? CME? version?
please always include that information when asking for assistance
basic steps would be to create a dial-peer or route patterns to outside world and use a translation pattern or translation rule to change the number to PSTN, pretty easy
java
if this helps, please rate
java
www.cisco.com/go/pdi
CUCM 4.1 Sorry
k, basic steps would be
decide the number they will dial for operator, if it's going to be 0 then just create a route pattern 0 and send it to the PSTN.
if something else then you can use a translation pattern or the route pattern directly, there is nothing weird on setting this. it's going to be like any other PSTN call
dial , match a route pattern, send it to PSTN
java
java
312
