Setup total 4 extensions with 3 FXO Ports.
What is the best way to add x533 which share both external incoming and outgoing call with x502 FXO port 0/0/2? My main goal is phone x533 can make external calls to outside and share the same number as (234)456-7890. Please see below for my current configuration.
Thanks in advance!
Phone (234)567-8900 to ext500 port 0/0/0
Phone (234)678-9000 to ext501 port 0/0/1
Phone (234)456-7890 to ext502 port 0/0/2
Add ext533
voice-port 0/0/0
description line 2345678900
caller-id enable
connection plar opx 500
trunk-group FXO1
voice-port 0/0/1
description line 2346789000
caller-id enable
connection plar opx 501
trunk-group FXO2
voice-port 0/0/2
description line 2344567890
caller-id enable
connection plar opx 502
trunk-group FXO3
Ext x500
# dial-peer voice 9 pots
# description *** For outgoing 9 Traffic to PSTN ***
# destination-pattern 1……….
# tone ringback alert-no-PI
# forward-digits 10
# answer-address 500
# trunkgroup FXO1
# dial-peer voice 10 pots
# description *** For 7 digit local calls ***
# destination-pattern [2-9]……
# forward-digits 7
# trunkgroup FXO1
# dial-peer voice 11 pots
# description *** For 911 Calls ***
# destination-pattern 911
# forward-digits 3
# trunkgroup FXO1
# dial-peer voice 12 pots
# description *** For 011 International Calls ***
# destination-pattern 011T
# no digit-strip
# trunkgroup FXO1
Ext x501
# dial-peer voice 13 pots
# forward-digits 10
# answer-address 501
# trunkgroup FXO2
# dial-peer voice 14 pots
# forward-digits 7
# trunkgroup FXO2
# dial-peer voice 15 pots
# forward-digits 3
# trunkgroup FXO2
# dial-peer voice 16 pots
# no digit-strip
# trunkgroup FXO2
Ext x502
# dial-peer voice 17 pots
# forward-digits 10
# answer-address 502
# trunkgroup FXO3
# dial-peer voice 18 pots
# forward-digits 7
# trunkgroup FXO3
# dial-peer voice 19 pots
# forward-digits 3
# trunkgroup FXO3
# dial-peer voice 20 pots
# no digit-strip
# trunkgroup FXO3
dial-peer voice 1000 voip
description *** CUCM Peer ***
destination-pattern 5..
Voice-class codec 1
Voice-class h323 1
Session target ipv4: 10.0.0.2
dtmf-relay h245-signal h245-alphanumeric
ip qos dscp cs3 signaling
no vad
1 REPLY
VIP Gold
For incoming calls you need
For incoming calls you need to send all calls to hunt pilot (e.g. 555) as below and then assign both extension 502 & 533 to this hunt pilot.
voice-port 0/0/2
caller-id enable
connection plar 555
trunk-group FXO3
for outgoing calls, you can modify the answer address.
Hope this helps you !!!
Suresh
26
