SFTP server for CUPS
I am trying to back up Cisco Unified Presence Server 6.0.4.1000-4 using Titan FTP server 6.24 which is Cisco's recommended SFTP product for Windows.
It fails when I try to add the backup device.
The same SFTP server works fine for CUCM 6.1 and Unity Connection 2.1.
I can backup the CUPS server using alternate SFTP software such as FTPD or Serv-U but need to get Titan to work.
Has anyone else had problems with CUPS and Titan and if so did you find a solution?
Green
Re: SFTP server for CUPS
Try different one, life FrreFTP, just to make sure is not Titan but CUPS
Thanks for the response.
I have tried the FreeFTPD and Serv-u SFTP servers which work ok with CUPS.
Freeftpd is to underdeveloped and cannot run as a service without a user logged in which makes it unsuitable as an enterprise backup product.
Serv-u is better but is not really an enterprise type product.
Cisco recommend Titan FTP in the CUCM6 and 7 Disaster Recovery Admin Guides so I would have hoped that it would work with all their UC products.
Has anyone successfully used Titan with CUPS?
451
