SFTP service on Linux box?
Has anyone ever used a Linux server to run the SFTP service? We were just about to upgrade from 4.1(3) to 5.1(3) and then were told that we can't use a Windows server for SFTP.
Re: SFTP service on Linux box?
well... you can definitely run SFTP on linux, but if you're more interested in windows, check out: http://www.freesshd.com/
there is no reason to not use a windows server as SFTP, i used my PC as SFTP when i upgraded my CUCM 5 server at the lab, i use it when i need to patch it and for the locales
you can try freeFTPD for that matter, really straight forward to configure and easy to use
java
if this helps, please rate
www.cisco.com/go/pdi
Thanks for the response.
We're being directed to use a Linux box for this function.
290
