SFTP trouble
I am trying to use Cisco Unified Operating System Administration/Software Upgrades/Install/Upgrade to install a .sgn file for a new type of phone. I put in the info for our SFTP server (using the Remote Filesystem choice), but when I click Next, the only thing that happens is the bottom left of the IE page says Error on Page. I can connect to the SFTP server using WINSscp, so I don't think the problem is with the SFTP server. I am using version 6.1.2.1106-1. Any suggestions would be appreciated.
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: SFTP trouble
The attachment.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Re: SFTP trouble
which SFTP server are you using? I suggest you use free FTPD
You can download on from here. Its free and easy to use.
http://www.sofotex.com/FreeFTPd-download_L30099.html
Attach is a documentation on how to use SFTP server with CCM5.1..Its the same with CCM6.1
VIP Super Bronze
Re: SFTP trouble
The attachment.
Re: SFTP trouble
Thanks for the info, but it looks like I just needed to reboot the phone server. Once I did that I was able to do the install with no problem.
311
