SG3 FAX Support
What Cisco platform do I need to support SG3 FAX?  ATA, VG2xx or FXS?
Re: SG3 FAX Support
Pretty much anything EXCEPT an ATA186.  You can use a VG224, VG248, or a voice gateway with an fxs port.  If I'm not mistaken, the new ATA188's can do T38, so SG3 should work there as well.
Re: SG3 FAX Support
The ATA187 is the new ATA which Chris is talking about.
It only supports low speed fax, though:
Fax Modem Speeds
The ATA 187 supports the following fax modem speeds:
14.4 kb/s
12 kb/s
9.6 kb/s
7.2 kb/s
4.8 kb/s
2.4 kb/s
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cata/187/1_0/english/administration/guide/sip/a187_ag7fax.html
868
