sh call active voice compact
can someone make an interpretation of the fields for me. When the call is orginate or answer what does that mean exactly and tele vs voip. thx
Re: sh call active voice compact
I'm running 12.4.10a on a 2811. When I run sh call active voice com, the second column isn't intuitive.
The router labels the incoming leg as "ANS" and the outgoing leg as "ORG".
If a person calls from the local gateway to a remote gateway, the command output lables the pots leg (incoming) as "ANS". If a person calls the local gateway from the remote gateway, the output labels the voip leg (incoming) as "ANS".
It's confusing because I would expect the incoming call leg to be "ORG" for originate, and the outgoing leg to be "ANS" for Answer. However, this is not the case.
James,
so if you saw
ans tele
org voip p 1.1.1.1
org voip p 1.1.1.2
org tele
does this mean that 4 fxo ports are tied up?
Tele = Pots call leg = the side the phone is on
VoIP = VoIP call leg = the side the IP network is on
1309
