11-07-2011 08:28 AM - edited 03-16-2019 07:55 AM
We are trying to make an external ringer work from a VG224 port and ring when an IP phone is called. After looking thru quite a few post, it appears that maybe this is not supported? Are there any work arounds or has anyone successfully made it work. We are running CM 7.1.5.1000-12. Everything I try breaks one or the other device. Once I remove the device from the VG, the phone will start back working.
11-07-2011 09:06 AM
Hi Rod,
There's no reason this shouldn't work as a first step try getting a simple analog
phone and IP phone configured with the shared DN. It's possible that the "ringer"
itself is causing you problems.
We use the Stinger Ringer (Model 196) from Dees Communications. We have used both an Analog port off a VG or ATA to power this device.This thing is super loud and works well for us. It is "line powered"
Here is a link to the actual doc:
http://www.dees.com/html/196_198.html
Cheers!
Rob
11-07-2011 12:34 PM
That is my thinking also. We have actually tested it using an analog phone and the ip phone will ring, but the phone connected to the VG224 will not ring. Looking in CM, the extension we are working with has both the VG port and the ip phone listed as associated devices.
11-07-2011 01:24 PM
Hi Rod,
We do this all the time, but with VG248's.
It almost sounds like a CSS or Partition issue.
Cheers!
Rob
