Community Member
Shared-line Appearance
Is it possible to set up the same DN on two separate phones as primary line. A user, who has two offices, would like to have a 7960 SCCP phone in each office using same DN number as primary line. CM version is 7.0
John
3 ACCEPTED SOLUTIONS
Re: Shared-line Appearance
Yes, you just configure the number as the 1st line on the phone in the same partition as a shared line.  When one
phone rings, the other phone rings.
Hailey
Please rate helpful posts!
Super Bronze
Yes, it is. Just assign the same DN and partition to the line on each phone, and both will simultaneously ring.
You may be better off considering using Extension Mobility if this type of scenario becomes common and the phone that is not being used is in an area where other staff might want to use it (or where the ring gets annoying if no one is there to answer it).
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yes, that is a Shared Line Appearance.
Hailey
Super Bronze
Aaron
Community Member
Is this setup (2 Phones share one DN as on Line1) called Shared-Line Appearance? If not, what is the proper term?
John
312
