Community Member
Shared Line on 9971
Hi Guys,
CME 9 with 9971. Can i have a shared line to an sccp phone?
thanks
Shared Line on 9971
Hello Aman,
Yes 9971 supports shared line
Take a look on this doc, Calling Features!
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10453/ps10512/data_sheet_c78-565717.html
Rate this if helps you!
Regards!
Community Member
Shared Line on 9971
sorry was more after the config. below is an example i took from another user on this forum.
voice register dn  1 -. Managers Phone
number 1234
call-forward b2bua busy 1000
call-forward b2bua mailbox 1000
call-forward b2bua noan 1000 timeout 18
shared-line
voice register pool  1
id mac x.x.x.x
type 8961
number 1 dn 1
cor incoming PSTN-INTL default
dtmf-relay rtp-nte sip-notify
username Manager password 1100
codec g711ulaw
voice register dn  2 -. Assistant Phone
number 1235
voice register pool  2
id mac x.x.x.x
type 8961
number 1 dn 2
number 2 dn 1
username Assistant password 1100
codec g711ulaw
I'm trying to create a shared extension between an manager and  assistant. However, I'm only getting the assistant phone to ring while  the manager phone does not show any incoming calls. is there a fix for this?
secondly, i need to add a sip phone as a secondary shared line to a sip phone. will it work and if yes would both phones ring at the same time as desired?
Community Member
Shared Line on 9971
just needed to create fake voice register dns . all good
898
