Community Member
Shared line with SCCP phone and a h323 client
I have a Cisco 827-4v router that I want to integrate into UCM6. I also have a 7940 that I would like to have use the same directory number on it. Since the 827 only supports h323, how can I setup a shared line so both the 7940 and a FXS rings on the 827 so both phones ring?
Thanks!
1 ACCEPTED SOLUTION
Green
Re: Shared line with SCCP phone and a h323 client
Not possible to do it so far since Device are different and we cannot internally extend the call to 2 devices....BUT thats when Mobile Connect comes into play.
You can configure your H323 as Remote Destination using Mobility Manager 1.X or CUCM 6.X.
1 REPLY
Green
95
