Shared Phone Voicemail Profile
CUCM/Unity Connection 7.1.3
I have a large number of phones that are shared with roaming Unity users (School teachers, no direct association between phone extension and VM extension). The primary extensions on the phones do not have a Unity mailbox. When the "MESSAGES" button is pressed I want to have unity play the login prompt, not the OG or anything else. Any assistance would be appreciated.
Thanks!
10 Replies 10
Jaime Valencia
Configure a direct call routing rule to go to login
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks Java ... can you tell me what the VM Profile would be so that when we press the Messages key on these phones it goes to the login?
Would I just set a mask of some unique DN and use that in the UCX rule?
Brian
Rob Huffman
Hey Brian,
In your original post you indicated that the "Primary" line
on these phones does not have any VM account associated,
if this is the case just use the same Profile as a phone that does
have VM. When a call comes into the Pilot from a phone that does not have
VM you should be at the Sign-In greeting. Press * (Star) then Extension, then PIN.
You should be good to go!
Cheers!
Rob
Hi Rob,
Thanks for replying. In this case we're talking teachers here ... so the client's IT manager wants to dumb it down a little   ;-)
They want to have the login prompt immediately when the MESSAGES button is pressed.
All main office staff or those that have their own phone will follow the usual config. The phones in classrooms will be shared by many teachers coming and going so they want the convenience of a single button press.
I'm thinking a VM Profile with a mask of say "8999" and a rule in UCX to route to LOGIN, but I'm not quite sure if this will work.
Any further thoughts are always appreciated.
Brian
Hi Brian,
Yes, this works like a charm I just tested this out. Make sure you set the Direct Call
Routing Rule to the "Sign-In" conversation. (and don't forget to re-order the RR's)
Cheers!
Rob
Excellent - thanks Rob. I'll set it up when I'm back at the client site tomorrow and post an update.
Brian
Hi Rob,
Old post ... finally got around to reconfiguring this and it's not working.
To review:
CUCMBE (CM 7.1.3.10000-11, Unity 7.1.3.10000-68)
My Config:
UCM Voicemail Profile "VoicemailLoginPromptOnly", Pilot: 8000, Mailbox Mask: 8999
UCM Test Phone, DN: 5500, Voice Mail Profile: "VoicemailLoginPromptOnly"
UCX Call Management>Call Routing>Direct Routing Rules, Rule: "Shared Phone Sign-In", Send Call to Conversation>Sign-In, Routing Rule Condition: Dialed Number Equals "8999".
Desired Effect: I press "Messages" from any phone using the VoicemailLoginPromptOnly VM Profile and I get Unity Connection's Sign-In. Right now I get the OG.
Brian
The conditions are wrong.
You do not dial 8999, you dial the VM pilot whenever you press messages.
CUC will see the call coming from 8999 to 8000.
Just reconfigure accordingly.
java
java
Java,
Yes, that's understood. The VM pilot gets dialed .... 8000. I think you're missing my point. I still need "standard users" to hear a normal login prompt "Please enter your password" when they press the messages button. This is when the extension matches the mailbox ID. Please see the original post for this message up top.
The users in question are those that have shared phones (the Mailbox id DOES NOT match the extension) and must hear the full Sign-In Prompt (beginning with "please enter your ID"), whereas they would normally hear the Opening Greeting.
If I set a rule to change calls to the VM pilot 8000 then all users will behave the same ... not my goal.
Hopefully this makes sense. I had concerns that a dialing rule wouldn't cut it ... at least from a point where we're looking at the dialed number, as you stated we're dialing 8000 (the VM pilot) not 8999 "the mailbox mask". The purpose of the mailbox mask was to provide a unique ID to Unity so that I can *somehow* identify the call as needing a "please enter your ID" prompt.
I think I solved it. You need to create a separate VM Pilot "8999" and Hunt Pilot "8999" for the Direct Routing Rule to work in Unity. Otherwise, no dice.
