Community Member
sharing Unity
I have a customer with 2 seperate clusters.
1 cluster has a unity 3.3 server.
the customer wishes to share the unity between the 2 clusters. There is a working trunk between the two.
Is this possible?
1 ACCEPTED SOLUTION
Re: sharing Unity
Unity can be homed into (2) different CUCM clusters. The only issue would be to make sure you setup the transfers from the directory to dial the correct integration.
In Unity Tools Depot
Manage Integrations
add the new cluster.
1 REPLY
Re: sharing Unity
Manage Integrations
113
