show ccm "backup ready continues to go down"
Issue here is that when I issue the command show ccm, my backup which is the publisher, goes back and forth between backup ready and down. I have multiple gateways that are running the same IOS and the issues doe not seem to be occurring there.
I looked at traces on the publisher and this is what I see.
02/04/2008 06:48:08.455 CCM|MGCPBhHandler 192.168.3.1 - internal ERROR wait_SdlConnectionInd - mMGCPBhGWInfo not clean on last TCP close!!!|<CLID::StandAloneCluster><NID::192.168.2.20><CT::0,0,0,0.0><IP::><DEV::>
I do not know exactly what this trace is telling me. The ip that the trace is referencing is the gateway in question.
The below is the output from the debug ccm-manager events. It looks as if the connection is opening and closing again
*Feb 4 15:01:34.643: cmapp_host_fsm: Processing event CONN_OPEN for host 1 (192.168.
2.20) in state STANDBY_OPENING
*Feb 4 15:01:34.643: cmapp_stop_host_tmr: for host 1 (192.168.2.20)
*Feb 4 15:01:34.643: cmapp_host_fsm: New state STANDBY_READY for host 1 (192.168.2.2
0)
*Feb 4 15:01:34.643: cmapp_mgr_process_event: Host 1 (192.168.2.20) is standby ready
*Feb 4 15:01:34.643: cmapp_mgr_check_hostlist: Active host is 0 (192.168.2.21)
*Feb 4 15:01:34.651: cmapp_host_fsm: Processing event CONN_CLOSED for host 1 (192.16
8.2.20) in state STANDBY_READY
*Feb 4 15:01:34.651: cmapp_start_host_tmr: Host 1 (192.168.2.20), tmr 0
*Feb 4 15:01:34.651: cmapp_open_new_link: Open link for [1]:192.168.2.20
*Feb 4 15:01:34.651: cmbh_open_tcp_link: Using MGCP bound IP addr 192.168.3.1
*Feb 4 15:01:34.651: cmbh_open_tcp_link: Opening TCP link with Rem IP 192.168.2.20,
Local IP 192.168.3.1, port 2428
*Feb 4 15:01:34.651: cmapp_open_new_link: Open initiated OK: Host 1 (192.168.2.20),
session_id=461CC274
*Feb 4 15:01:34.651: cmapp_host_fsm: New state STANDBY_OPENING for host 1 (192.168.2.20
1 REPLY
Re: show ccm "backup ready continues to go down"
Well it seems to have been resolved. I just restarted the ccm service on the publisher from the control center. Service seems to be steady now and not bouncing back and forth between down/backup ready. Not sure why that happened though.
143
