Community Member
show gatekeeper calls shows nothing
People, I need advice.
I am setting up a test Gatekeeper-controlled trunk between a CCM4.1.3, a 3845 gateway and an AVAYA PBX acting as a second gatekeeper/gateway.
The trunk has been properly setup and calls go back and forth both ways without issue, but when I execute the command "show gatekeeper calls" returns no calls, despite one test call being active at the time.
We already tested shutting down the gatekeeper to be sure that the call goes through that device (it fails, as expected).
My customer believes he already saw such behavior once, where the gatekeeper is already configured as a gateway on the CCM (for other types of calls) and in such case, listing the calls on the GK returns zero.
Is this so? Hasy anyone experienced this before?
Best Regards,
Ariel
1 REPLY
Anonymous
N/A
Re: show gatekeeper calls shows nothing
Please send show version and show run of the gateway and gatekeeper so we can help.
124
